I haven't tried yet, but will XCopy Express make a copy of one of its backups?
"Burn a burn" ?
I heard you couldn't, and I didn't want to make a coaster trying.
Thanks,
H.
From your direct question, the answer is no. The reason is very simple. Any DVD backup software from 321 Studios puts a small txt file at the root of the DVD. The txt is the "copy protection" flag that is looked for when using 321 Studios software to create a backup from a backup.
All this means is if the txt file is present, then the prgram will noy allow you to preceed.
If you have a backup created by 321 Studios, then the Macrovision and CSS type protection are already removed. PLus your backup is already broken down into a DVD-5 (current recordables).
You can make a backup of the 321 Studios' version just by copying the VIDEO_TS folder onto your hard drive and then importing it into standalone burning software like Nero and Roxio applying "DVD-Video" settings.
Corel VideoStudio Express 2010 - cannot "see" h264 files ???
By andy15star in forum EditingReplies: 13Last Post: 6th Sep 2010, 16:29 -
Getting "Fair Use" copy of last "Byrds of Paradise" episode
By Ronald Vaughan in forum Newbie / General discussionsReplies: 4Last Post: 14th Jul 2010, 22:09 -
Final Cut Express - Edited for 2 weeks in wrong "preset" how do I change it
By Chrushev in forum EditingReplies: 8Last Post: 12th Apr 2010, 05:08 -
Can I bypass "copy blocker" to copy from VHS to DVD
By jgloeckner in forum Newbie / General discussionsReplies: 10Last Post: 23rd Nov 2008, 00:40 -
Need suggestion for cheap or free "incremental" backup software x
By yoda313 in forum Off topicReplies: 5Last Post: 6th Jun 2007, 12:13
