I burned SVCD movie from image and all works great, then i took this CD to a friend's house and he wanted to make a copy for himself, put blank CD in , put my SVCD CD in and tryed to do CD to CD direct burn and oops it didn't work, not enough space...weird. From image is enough space but from CD to CD not! Can someone explain how to copy that CD ? Thanks.
Some drives have trouble reading svcds. Did you try doing all from the burner so it records to the hd before burning?
What software is he trying to burn with. Some of the free software is not good for burning SVCD because u can fit 800 MB of mpeg2 video data on a 700 meg cd. So it cause some confusion for some software. "ex. first release of EZCD6" i couldn't copy SVCD disk but i could author them properly try using Alcohol 120% to copy SVCD disk seems to work better fireburd and CDRWin are other choices.
I would rip it as Global Image file with RecordNow Max /DX and burn it as Image Job.
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Thanks slot, i'll try Alcohol next time... strange though that .mpg file is about 800 MB and it all fits to a 80 min CD
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23 -
cannot copy 22.5 Gbyte file with Win XP copy command
By maxtrack in forum Newbie / General discussionsReplies: 7Last Post: 2nd Aug 2007, 14:12 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 10:27
