I'm trying to re-master a home video that I put on DVD last year. The menu wasn't very good and I wanted to clean it up. I downloaded the trial version of TMPGEnc DVD author version 1.5.15.49 and installed it.
I then extracted the video and audio file using DVDDecrypter in stream mode (demux setting). After that I multiplexed them using TMPGEnc into a single mpg file (which plays perfectly all the way thru in Windows Media player).
I imported the resulting mpg into TDA and proceeded to set chapter points and create menu's, everything went very well with no indication of trouble.
The problem is:
When I output it into a VIDEO_TS folder half of the main movie is gone. Instead of 3.5gb its 1.5gb.
Has anybody else run into this?
I'm running an AMD 2700 with an MSI Mother board with a gig of ram.
Thanks for your help
Sometimes the menu shows up as "subtitles" in DVDDecrypter. Try not demuxing? Use Stream Processing but only remove "subtitles" if that is the way your original DVD is set up. That's how I remove the menu from my Philips DVDR985 created discs.
I could be wrong....DON'T STONE ME...
Thanks for the feedback. I also contacted the developers of TMPGEnc DVD Author and they suggested just importing the original VOB's and re-master from that. They claimed it was more reliable. It sounds like I have some experimenting to do. :P
Success! Importing the DVD info(vob) worked perfectly. I was able to import the titles and put a new menu on, and it looks great.Thanks for the feedback. I also contacted the developers of TMPGEnc DVD Author and they suggested just importing the original VOB's and re-master from that. They claimed it was more reliable. It sounds like I have some experimenting to do.
i need help to remaster my old vhs tapes to dvd quality(for mac or windows)
By ultimate15red in forum EditingReplies: 2Last Post: 12th Nov 2009, 07:13 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 18:53 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 11:00
