Hi guys ,
Is there a way to back up playstation2 dvd games to dvd-r?
Can i burn them with nero or i have to use a spectial software to do that ?
thank you
Results 1 to 25 of 25
backing up ps2 games is simple, you really should use the search feature.
this has been discussed so many times. -
yep
they have no copy protection on them so thats all you need to know & use -r media ONLY -
actually, they do have copy protection. but making a backup of them that is playable with a modchip/swap method is easy.
I have a few PS2 backups done.
I have used + and - R media and both have worked fine. I think deciding what media to use is related to the PS2 version and your mod chip version, but I could be wrong. I know I have a version 7 (I think) PS2 and I have no idea about my mod chip. But so far, my PS2 has played everything I have put in it. Even some stuff that my standalone (Panasonic RV-32) cant play.
I used Stomp Record Now and got a coaster. I switched to Alcohol 120% and am 3 for 3 so far.
I have an LG-4040B.
LG -
A simple enough question, why not just answer it, instead of bollox
yes you can use nero, but you'll find it far easier to use dvd decrypter to make an iso image of the game then burn to dvdr, you can use + or - dvdr's , but stick to decent discs, to avoid coasters, IE Ritek.
Hope this helps -
No probs. I use Stop Record Now DX with my Sony DRU-500AX. Build an image of the PS2 game using Record Now Max/DX BUT select the read speed to minumum. After image has been created burn image back onto a DVD _/+ (I believe versions 4 and below are capable or reading minus R and above 4 can read any)....although mine is a 4 and will read a plus R movie, not tried a game yet. When burning to DVD select 1x write, slow but you will get a better burn.
Also the quality of the media is very important. DO NOT use cheap disks. I started trying budget disks but the game sometimes took 10 attempts to boot. I now only use Ritek DVD and they boot first time. -
"actually, they do have copy protection"
I was just keeping it simple, not to get into the complexities. If I say no copy protection then people can just copy otherwise we would spend hours trying to explain how it really works. -
So what do i do if i had a copy proctected game? Dvd Decrypter will do the job? what mode?
Does anyone know how to burn the game true crime for ps2? all my copy games (fuji dvd -&+ media) work but this one wont. i tried diff media, i went from compusa dvd media to fuji media and nothing. the game loads but right after it loads it give me a error saying load a ps2 format disc. its not my modchip, help me if ya know something....thank you...
What chip and what version ps2 do you haveOriginally Posted by madrato
Tru crimes works great on my version 7 with magic 3.1 and my version 7 with a messiah 2 ver 1.3 -
Easiest way I know of is to use DVD Decrypter.
Using DVD Decrypter
1. Start DVD Decrypter
2. Select Mode, go down to ISO Read
3. Select your Reader & Destination
4. “Decrypt” the ISO Image to the Hard Drive
5. Wait for the ISO Image to be made
6. Select Mode, go down to ISO Write
7. Select the ISO Image file you made, click “Open”
8. Select your Burner, Write speed & Burn the ISO
Remeber You'll need a mod chip to actually play your backupsWhat We Do In Life, Echoes In Eternity.... -
my ps2 version is SCPH 39001
my mod chip is No Solder R Mod w/swap magic disc. -
I just tried the dvddcrypter, i did everything you said (just the same) and when my ps2 says "insert disk" i insert the copy TRUE CRIME and right after the "luxaflux" logo it gives me the error saying please insert a ps2 format disk...please help.
hmm.....let me get back to you maybe I wrote it wrong?
I'm not sure why you are using DVD Decrypter to copy PS2 games. That might have something to do with your problem.
I have a Messiah 2 chip. I backed up True Crime just like I backed up every other PS2 game I own: I placed True Crime in my DVD ROM, a blank DVD-R in my DVD burner, opened Nero and hit "copy disc." I burned at 1x and I have had no problems with the backup.
It seems to me that some people are making this much more complicated than it needs to be. -
That is your problem there are at least 20-30 games that wont with swap magic unless you use the cogswap loader disk and this is one of those games.
Look here for more info
http://www.swapmagicfix.com/ -
I'm new to burning PS2 games, what I know about it is what I read on these forms, so thanks to all who have questions and specialy the ones with the answers, I have a question about certain PS2 games, I have Contra Shattered Soldier and it is blue, what I mean is when you look at the side of the game that is not labeled it is blue not clear like a regular PS2 dvd games, anyone know why it is blue? the computer can not read this game, has anyone backed up games like this and how was this done, thanks in advance
is it a thread jack if the thread is over a year old??Originally Posted by familyguy.68
:P
the blue ones just mean that they are a cd not a dvd. maybe to a google as far as backing up goes -
What you need is a device called a swap disc and flip top cover to play your leagally owned ps2 games, you can find that product at www.maxwaves.com I haved purchased 2 items from them with great results and good customer service. And the good thing about that product is no mod chips and it's easy to use.
blue bottom discs,-copy disc in nero,but some are slightly bigger than normal cds,so invest in a few 800meg-90mins cds.
the latest one i had like that was sega superstars for the eyetoy.
as for silver bottomed dvds, dvddecrypter,iso read,iso write.
simple,if it then doesnt work,its the media,or your mod chip
thats it plain and simple in a nutshell.
if you want to ask about copy pretected games,your talking about a different console,not the ps2.
ive not come across a game i cant copy this way,and that didnt work like this -
wow that was fast, thanks for the infomation, I have burnt 9 dvd games so far useing dvd+r's and dvd decrypter, I bought the magic swap disc with slide card and no problems playing dvd games, it was those blue disc games that stumped me, now I know what to do, thanks again, I'll have to try Nero with the compact disc games(blue disc), this is so cool, thanks again
Blue bottom disks are cds
There are no ps2 cd based games that are over 650mb AFAIK
If you are having problems copying and playing your blue bottom disks then your swap magic cd (not the swap magic dvd) is probably defective
or you might want to try different media
Backing up XBOX games
By HARRYSPADGE in forum ComputerReplies: 22Last Post: 16th Feb 2013, 20:27 -
Backing up of Wii games?
By freebird73717 in forum Off topicReplies: 6Last Post: 6th Dec 2011, 12:10 -
Backing up my PS2 games....
By SE14man in forum ComputerReplies: 23Last Post: 16th Jan 2008, 12:12 -
Backing up Games?
By LCE in forum Off topicReplies: 2Last Post: 24th Oct 2007, 00:45 -
Backing up EA Sports Games
By drew23977 in forum Off topicReplies: 3Last Post: 19th Jul 2007, 02:09
