Is there is utility that allows me to say crunch this movie to fit on a 700Mb CD?
I have a number of DivX format files that are just a little too big for a single CD. I want to crunch them down, but keep them in the DivX format.
I know I can do this by playing with different settings in VirtualDub, but I would like it work out what frame rate, res etc to use to get the file to the right size, so I do not have to try a variety of settings to get it to fit. Which is tedious when you have a few files to do.
I do not care if it takes a very long time to run (because it has to run the different possibilities), just as long as it sorts its self out, rather than me having to do it.
If you are just storing use winrar to compress then burn as data cd's, or you could try CopytoDVD it has several options including CD. You could also try some of Kwag's(KVCD) or Sefy's templates here:
https://www.videohelp.com/tools?section=26#26Just shut up and listen dumbass -
the audio & video in a divx movie is already compressed to hell. you wont get it any smaller by compressing it.
your best bet is to take it in to virtual dub & cut out the credits (use the guides to the left).
or you could re-encode the audio to a lower bitrate or even a variable bitrate mp3.. you'll need to use nandub (a virtualdub mod).
you might even have to do both those things.
Can you fit multiple movies on bluray media?
By rz514 in forum Authoring (Blu-ray)Replies: 12Last Post: 28th Apr 2013, 00:29 -
How to Fit 3 movies on 1 DVD 4.7GB and keeping high resoultion and quality?
By Virius in forum Authoring (DVD)Replies: 4Last Post: 8th Aug 2009, 16:12 -
converting movies to small format
By fsmith4 in forum Video ConversionReplies: 2Last Post: 15th Nov 2008, 04:02 -
fit 3 movies to dvd5
By thecrock in forum Newbie / General discussionsReplies: 9Last Post: 19th Jul 2008, 15:00 -
Archos for recording TV movies for later conversion into Divx format
By guy1955 in forum Portable VideoReplies: 0Last Post: 23rd Jul 2007, 07:46
