Hey gang,
Just got my first DVD drive, a Sony DRU-510A. I've spent the last 2 days days trying to get a CDRW disk that I have all of my digital pictures on to read in this drive with no avail. It reads in other computers, but not in my main one. Anyway, that's a whole nother story.
People have told me that the packet writing, or DLA as I knew it, is flaky and to try best to avoid it. I've had Nero 6 Ultra and DVD X Copy coming, so I guess that's the software that I'll be using. Are there any good alternatives to packet writing software? I don't want to make disks now with this drive and software, and a few years now the road be stuck not being able to read the disks like I am now.
I really like the direct access to the CD. If there's no good solution, is the next best thing to keep and organize my digital pictures on the HDD, and then keep moving this over to DVD+RW every so often, instead of just doing the adding, deleting, moving, right on the disk?
Thanks in advance,
Aaron
PACKET WRITING WORKS FINE on cds with the nero driver/program incd. howver I found it was a bit of a waste as basically you lose approx 200mb of 670mb on a std cdrw. What I decided to do was just to use cdrw as ordinary cdr and just erase completely whenenever I needed to redo the contents. If you use multi-session recording you can just add when you like till its full. HOWEVER I beleive there is no such thing as multi-session with DVD(rw). How many pictures do you need to store?? 670mb @ 700kB (jpeg) per pic is a lot of pictures. If they are really precious I would just burn them to a CDr and use that as an archive instead. DVDrw would take even at 9mb per raw TIFF image approx 2000+ images. ANd dont forget to backup that DVD.
RW media good for around 1000 erase/ cycles .....
a good alternative to imgburn
By marlo in forum Authoring (DVD)Replies: 5Last Post: 11th Mar 2011, 11:59 -
Premiere RGB exports produce bad frames - is YV12 a good alternative?
By spicediver10191 in forum Video ConversionReplies: 5Last Post: 21st Feb 2011, 17:02 -
What is packet bitstream and what is it good for?
By chupacabra in forum Newbie / General discussionsReplies: 20Last Post: 25th Sep 2007, 08:13 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 12:03 -
Time Warner Cable Implements Packet Shaping
By BJ_M in forum Off topicReplies: 6Last Post: 19th Jun 2007, 22:41
