Hi there all !!
I've just purchased Gladiator and wanted to make a copy of it for protection of the original.
I worked it out with DVD2ONE but the final quality was not so good.
I decided to make only the movie with Digital 5.1 sound and English and Greek subtitles. The result was better.
DVD2ONE created all the necessary VOBs and IFOs so when i insert the DVD-R into my player it starts directly the movie and i can change the subtitles state (ON/OFF or change from Greek to English) from my player's remote control.
Can i create a custom menu by capturing a scene from the movie or even using some JPEG/TIFF as background and make some menus referring to the chapters and to the subtitles?
If so what software should i use ?
My new DVD Writter (Plextor PX-708A) comes with Ulead Authoring Software. Can i used it for this purpose?
Thanking you all in advance.
Please post everything regarding DVD to DVDR Reauthoring in the DVD to DVDR forum. I'm moving this topic.
Why not lock this one?
He already crossposted it there...You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
and was that a problem for u ?
I just wanna find a solution to this problem.
Isn't this the reason you all created this side ?
gosh !!!1 -
1. You did not search to solve your own problem before posting.
This site if full of guides and threads about this...
2. You are crossposting.
Read the Forum Rules
https://www.videohelp.com/forum/viewtopic.php?t=124514You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Convert VOB files to Divx with DVD menu
By xtof in forum Video ConversionReplies: 1Last Post: 1st Mar 2011, 15:29 -
Menu Creation in DVDAuthorGui
By larrytxeast in forum Authoring (DVD)Replies: 3Last Post: 23rd Jul 2010, 11:52 -
Making a DVD menu from .VOB files created by FAVC?
By whatever911 in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2009, 03:13 -
Frustrated and Lost ! All I need is a simple menu for VOB files
By vulcan_man in forum Authoring (DVD)Replies: 7Last Post: 26th Feb 2008, 05:12 -
create menu for 2 movies with several vob files with guifordvdauthor
By aruwin in forum Authoring (DVD)Replies: 1Last Post: 30th Dec 2007, 05:22
