  1. how long does it take to encode/decode, a dvdto a hard drive. right now with dvd shrink it takes about an hour and it reads like a 2x is that about right? i got a basic 16x dvdrom, 2.4 p4, ide133 but 100 hard drive, western digital 7200rpm 8mb buffer, 512 pc 2700 ram? is this how long it takes to decode/encode or is there a faster software, or is it my dvd rom? just wondering cause it seems like it takes forever
    Oct 2003
    Central Texas, USA
    When I use DVD Shrink to rip and compress a movie onto my HD, it takes around 45 minutes for a 2 hour movie. However...when I use DVD Decrypter (free), it takes around 10 minutes. If you are just wanting to view them from yer puter, this is the software I'd use.
    There could be several reasons why yer DVD-ROM rips slowly. That particular ROM may be set to run slowly when ripping (Some are set that way by the manufacturer to dissuade us from ripping). DVD Shrink may not like your ROM drive. You may need to change out your ASPI layer. Do a search in the forums for ASPI and you'll see more info on that. Another thing u might try is defragging yer HD. I've seen posts where folks report faster rip times after defragging.
    Your system appears to be plenty fast and agile enuff to rip faster than 2x, but different software behaves differently on different systems. You just need to experiment to see what works best on yours.
  3. If you're properly re-encoding (not just transcoding) with something like TMPEGenc, you could be talking DAYS if your computer is a bit of a dinosaur...
  4. With your spec you should only be looking at acouple of hours.
    If it's wet, drink it
    My DVD Collection
