I've been testing the Napa 311 I have found some issues about this player...
If I directly encode a video directly from the source in vcd format with no additional encoding it plays great with very little jerking. But, if I have a high quality capture and use re-encoding programs like Tmpeg, it jerks horrobly, though it plays beutifuly on my Philips DVD 711.
I guess the Napa 311 wasn't programed to play VCD photos because the player did reconized the disc but stayed on the Napa startup screen.
Playing MP3's through the TV sucks but other than that through the headphones it sounds great!
Does anyone have any tips for making better VCD's for the Napa?
Unfortunately, it seems that all portable players suck ass when it comes to play VCDs...
I guess this my cause ... I continue to post my two cents worth every time a new thread is started.
I've found the key to good video playback on Napa/Tanky/Waitec VCD players:
. output bitrate at 1123kbps
. use a small group of pictures; in TMPGEnc I use a setting of 1-2-1-1 (the last "1" is important for entrypoints)
. use an authoring program like videopack 4; vcdimager should also work fine, but i have not yet tested a vcdimager disk in the napa (on my to-do list for next couple of weeks)
Keeping The Old Workhorses Working
By sanlyn in forum ComputerReplies: 11Last Post: 31st Oct 2011, 05:50 -
Keeping subtitles without transcoding
By bobo343 in forum SubtitleReplies: 6Last Post: 11th Jan 2010, 11:05 -
login not keeping password....
By rubberman in forum ComputerReplies: 3Last Post: 25th Jul 2008, 14:13 -
Ripping and Keeping HD Audio
By SeeManRun in forum AudioReplies: 0Last Post: 26th May 2008, 23:00 -
Keeping them clean!
By willmoodom in forum Portable VideoReplies: 2Last Post: 22nd Dec 2007, 20:05
