Hi,
I have a collection of videos on various formats, DivX, MOV, ASF, AVI, MPG, etc....All are different resolutions/bitrate etc.....
I want to combine/join all of them using one tool and make them into a mpeg thst I can burn as a CD.
What's the best way I can go about doing this?
Thanks,
CJ
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
Read the avisynth manual
Avisynth is a frameserving program, it will allow you to take various source video/audio clips and join them together or back-to-back, and then you can feed the AVS (avisynth script file) to TMPGenc or CCE to encode one huge MPEG.
The other way to go is to just generate a lot of seperate MPEG files, then when you author place them back to back. Depending on how you author there may or may not be a slight pause between each MPEG/track. You said CD (which to my mind = VCD/SVCD/CVD and NOT DVD) so there would be a slight pause between each MPEG file. -
Great, tried working with this fantastic program and could load all my avi's and mpg's and source them to tmpgenc
The only problem I have is that when I try to load a .mov file, it fails saying something about class not being able to load or something. I even added the fps 29.970 to the line and it still woudn't work.
Any idea how I can load all the mov's?
Thanks,
CJ -
Please TRY post in the right forum. This has nothing to do with DVD to, I'm moving it to the conversion forum.
Canopus Procoder does this very nicely using the "stitch" feature. Just load everything (.avi, .mov, mpeg, .divx), check stitch, check your output format (VCD,etc.) and let it rip.
hd formats
By devdev in forum EditingReplies: 6Last Post: 31st May 2010, 17:35 -
Organize Various Formats
By fran_risquez in forum Software PlayingReplies: 0Last Post: 24th May 2010, 20:37 -
Why so many formats?
By sequoia in forum Newbie / General discussionsReplies: 3Last Post: 30th Sep 2009, 17:39 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
DVD Formats
By Bluenote58 in forum MediaReplies: 9Last Post: 30th Sep 2007, 06:23
