hello guys
i do have avi file with ogg audio stream...do not know who did so stupid thing but....i need to extract audio to wav and after that reencode again with regular mp3 codec.....anybody knows how to do it please?
thanks
If you can demultiplex the ogg file,Easy CD-DA Extractor can convert the ogg directly to mp3.
Hi,
I'm no audio conversion expert, so i just typed "convert ogg wav mp3" into www.google.com and got this at the top of the list:
http://www.audio-converter.com/
It's trialware and does 10 conversions of each type, then you have to pay ($19.95).
Google also returns a lot of other results that also look promising.
Hope that helps...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
i just tried to convert my 1 mono channel ogg file with easy cd-da converter but version 6 does support STEREO files only.....
then i tried latest BeSweet but it crashes too after pushing convert button...probably the same reason because my ogg file is MONO...
any ideas how to convert ogg mono file to wav please? -
Have you tried opening the avi file in either GoldWave or Audacity?
Both of them support the OGG format, and GoldWave is a very good app for extracting audio from avi's in general.
cheers,
mcdruid.
P.S. I've just double-checked, and Audacity supports OGG out of the box, whereas the GoldWave manual says this:
Ogg Files
To work with Ogg Vorbis files, GoldWave requires a copy of the CALOGG00.DLL module in the Windows\System or WinNT\System32 folder.
For the download location of that module, please see the GoldWave website:
http://www.goldwave.com/release.html#optional
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 10:07 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 12:38 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 15:26 -
cannot extract wav from AVI
By ecc in forum AudioReplies: 3Last Post: 22nd Jul 2008, 18:21 -
Extract audio to WAV using VirtualDubMod
By jimmalenko in forum User guidesReplies: 15Last Post: 14th Nov 2007, 02:42
