I followed the guides here first encode my 23.976 fps AVI using CCE and then use the PULLDOWN tool to convert the framerate into the NTSC standard 29.97.
However when I authored the so-generated MPEG2 into a DVD, I got a warning saying that the GOP length is longer than standard and may not play in all standalone players. The long GOP probably was caused by the pulldown.
Can anyone suggest pulldown tools or steps that would make the end MEPG2 DVD standard compliant?
Pulldown should have no effect on GOP length. In CCE on the GOP settings tab did you set M to 3 and N/M to 4? If you use the default settings of 3 and 5 then your GOPs will be too long for 23.976fps footage.
install Win2008 Server STD Government Volume License on Server with no O/S
By retroborg in forum ComputerReplies: 5Last Post: 11th Nov 2008, 09:18 -
P-STD buffer underflow: how to calculate correct bitrate?
By fvisagie in forum Authoring (DVD)Replies: 4Last Post: 6th Oct 2008, 10:51 -
Help to batch convert Std Def MPG Letterbox 4:3 to Anamporphic 16:9
By jmone in forum EditingReplies: 0Last Post: 6th Jan 2008, 01:22 -
Using pulldown
By MysticE in forum Video ConversionReplies: 2Last Post: 14th Jul 2007, 03:25 -
DVD has (2) versions WS & std, how to back up only WS ver ?
By theewizard in forum DVD RippingReplies: 9Last Post: 6th Jun 2007, 16:00
