I know this has been discussed many times. From the links I follow I'm not finding the answers to my questions. I am trying to backup a DVD movie. I want to retain the different audio options (2.0 and 5.1), get rid of the subtitles and extras, but keep the menus. What is the best/easiest way to go about this?
Results 1 to 10 of 10
if u use the method at http://expage.com/howtocopydvds4free
it is very easy, when u use dvdshrink u can chose what you wantGo to http://www.expage.com/howtocopydvds4free it Rocks! -
DVD Shrink will do what you want and it's free. You can compress the main movie up to 70% of its original size without any noticeable loss in quality. For more reduction is size, Pinnacle's Instant Copy 8, or IC8, will do just fine.
DVD Shrink can be used for ripping directly from the original DVD, and it's fast. If you want to keep the main movie without the extras and menus, in its re-author mode, it will allow you to trim the credits from the end of the movie. A great, great software. -
DVD Shrink in the re-author mode will not allow you to keep the menu.
It´s important to understand the question post by BLaRG.
Only soundforbjt opinion is correct.
BLaRG needs re-author mode to put all in only one 4.7 DVD and keeping the menu (audio, subtitles and extras).
With DVD Shrink that´s not posible.
Bye. -
I just did this last night, I followed a guide I found here.
https://www.videohelp.com/forum/viewtopic.php?t=175347
It worked fine through testing with windvd, Im burning it now to test on standalones.
autorf
Backup DVD can't be read normally, menus don't work
By chtit_draco in forum DVD RippingReplies: 7Last Post: 18th Apr 2009, 09:30 -
Extremely easy backup solution.
By Poppa_Meth in forum ComputerReplies: 9Last Post: 19th Nov 2008, 10:14 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Remove extras and keep the original menus
By jujuandhuhu in forum DVD RippingReplies: 4Last Post: 7th Mar 2008, 08:55 -
keeping the menus, removing the extras
By Belfour in forum Authoring (DVD)Replies: 5Last Post: 23rd Jul 2007, 09:27
