    Nov 2003
    How do u change the USB 1.1 to 2.0, can this be done by putting in a pc card in a empyt slot, an if so, what do you do to the old 1.2 or do u unload it or etc ?????????? Being a novice, im not quite sure how to do this & then again where do I get the USB 2.0 card or info about it.
  2. You can get an USB 2.0 PCI card at your local computer store. Just plug any USB devices directly to the card and not the MOBO.
    Nov 2003
    Sorry, I dont know what a MOBO is ????????????
  4. "MOBO" = motherboard
    Replace your USB 1.1 card with a 2.0 card. The card plugs into the motherboard.
  5. You will probably still haVE YOUR OLD USB1.1 as well as your new card with usb2.0 . You can still use both but obviously hi-speed is only available on the new port. You sound like you are not technical enough to fit a card, it is easy but let someone else do it and watch them.. next time you can do it!
    Hint... find out what F U B A R means....
    The electronic components of the power part adopted a lot of Rubycons.
  6. Yes, I Know Roundabout's Avatar
    Jul 2003
    ...in and around the lake
    It looks something like this:
    $8.00 at newegg.com
    http://www.newegg.com/app/viewproduct.asp?DEPA=1&submit=Go&description=usb%2C2%2E0%2Cpci%2Ccard
    or you can buy one locally at someplace like PC Club or CompUSA, Best Buy, etc. Plug it in and go. Instructions come with it. Easy. Don't worry.
    Ethernet (n): something used to catch the etherbunny
  7. Banned
    Oct 2003
    Americas
    8 bucks a card, 10 shipping, interesting
