Hello!
I have been practising ripping a DVD from my local video store and installed anydvd and had alcohol readily installed.
I had a look at the DVD and found the contents to be larger that they can fit onto one DVDR so I installed Shrink to ideally compress the movie to fit in.
So I decided to rip the DVD to the HDD instead
The ripping and encoding process went well except for the directory structure all of the files are in one directory. Apparently Shrink copied all to one directory.
How can I avoid this mistake next time? thanks
All files should be in the VIDEO_TS folder.
Have a blank AUDIO_TS folder in the same location. -
2) Go buy the DVD and practice on that.
Errors on Shrink ripping latest hit dvd's
By bluzjamer in forum Authoring (DVD)Replies: 9Last Post: 6th Dec 2010, 00:13 -
Compressing .vob or .ifo files using DVD Shrink
By hostofsorrow in forum Authoring (DVD)Replies: 4Last Post: 21st Jan 2010, 22:19 -
How to shrink the file size of 7.63GB after ripping the DVD?
By coy228 in forum MacReplies: 6Last Post: 16th Jun 2009, 09:19 -
DVD Ripping to HDD
By Dan Dare in forum Newbie / General discussionsReplies: 3Last Post: 20th Nov 2008, 12:42 -
Ripping A DVD onto the HDD in a Viewable Format
By kiln in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2008, 16:42
