Okay, here's my story:
Downloaded and tryed out SVCD2DVDMPG. Worked fine.
I thought I'd try out the demo of SVCD2DVD and tried to download it four times, each time the download would stop halfway through and a message box would tell me I had lost contact with the server.
Today I decided to just go ahead an make the "donation" and get the full version, which downloaded fine. Everything seemed to install fine, but when I opened the program I got a message:
"Unable to perform automatic update... Check to get 'SVCD2DVDMPG+' update manually. You need to do this before you can run program."
The problem here is that I don't have internet access on the machine which I am installing the program. The machine which I downloaded the software on is my work machine which I don't use for personal purposes.
So how do I get around this automatic update requirement to use SVCD2DVD?
snappydogGuest
You use your serial/email to get to the SVCD2DVD update area download the updates you need. Get them to your home PC & unzip to the SVCD2DVD folder.
Other wise you can email me & i'll send you the updates.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
snappydogGuest
You know, I tried that several times and it just wouldn't work. It turns out that I wasn't putting the dash in front of the serial number. When I did that it worked just fine. Thanks for the help.
Same problem, upgraded to 1.5 and it want let me start the program without automatic update. I am behind a firewall and it just sends me to this http://www.alternativemallorca.com/SVCD2DVDMPG/AutoUpdate/E343C1C9-5971-46B6-7EF3F0432...Email=xxx@xxxx
webiste. (serial and e-mail replaced with x's by me here).
Then I cant get any further.
Have manually updated to latest version, but no go.
Yours -
con999: drop me an email & I'll sort it out for you.
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 15:52 -
How to Update Your Duplicator's BIOS. you need to update
By krrish in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Apr 2011, 12:02 -
Automatic cropping
By didikai in forum Newbie / General discussionsReplies: 0Last Post: 6th Dec 2008, 10:20 -
Codec Required part two update
By booyaka in forum DVD RippingReplies: 8Last Post: 14th Dec 2007, 23:25 -
Automatic updates?
By fLYtRap in forum ComputerReplies: 11Last Post: 13th Jul 2007, 16:46
