Anyone have an idea where I can get information on the percentage of players will play a disc without the AUDIO_TS folder??
Been looking for 2 days now and have come up blank, although I have plenty on the DVD-R vs DVD+R issue![]()
What I said is not what NOT what you heard
It doesn't come up very often. I've never seen a survey becasue most people won't waste a disk to test it. It is 'required' but the DVD specifications.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thanks Gaz,
Now where did I put that url for the dvd spec page hmmmm??
What you heard is NOT what I said
i really dont think the AUDIO_TS folder is that important.
i'm sure we would have heard by now if it was.
there are quite a few major release movies that dont have the AUDIO_TS folder.
i still burn a blank AUDIO_TS folder, just incase.
but i dont think its a big deal either way -
I don't believe players really need this AUDIO_TS folder (unless of course its a DVD AUDIO TITLE..then the .AOB's are in there)
I believe the need for this folder is a historical accident..
I believe the custom of includiong this optional folder was done because of a MAC if you use TOAST and only drag one FOLDER TO THE APPLICATION..then toast errs and opens the folder to create a DVD called VIDEO_TS with the .VOB's in the root directory...
WE ALL KNOW THIS IS A VIOLATION OF DVD SPEC AND WILL NOT PLAY -(even in a pc)
SO I BELIEVE the inclusion of the VIDEO_TS 's companion folder..the AUDIO_TS ....was a quick way to insure proper folder architecture on the first DVD authoring systems..
REMEMBER on A MAC you only have 2 choices..the program itslf..or TOAST -
Thanks all for the responses.
Gonna have to make a deep info dive into the LOC (Library of Congress)
abyss.
Duplicate a DVD....can you simply copy Audio_TS folder and Video_TS folders
By True Colors in forum Authoring (DVD)Replies: 6Last Post: 29th Apr 2010, 14:37 -
I don't get any movie.DVD folder (audio_TS & video_TS), help!!!
By dbedolla in forum MacReplies: 1Last Post: 10th Nov 2009, 03:21 -
AUDIO_TS folder
By siluet in forum Newbie / General discussionsReplies: 14Last Post: 10th Oct 2009, 07:00 -
HELP!!. . .DVD Without AUDIO_TS Folder???!!!!
By sniperloc in forum Authoring (DVD)Replies: 13Last Post: 17th Feb 2009, 12:29 -
Another folder than Video_ts and Audio_ts
By claudiofran in forum Authoring (DVD)Replies: 12Last Post: 3rd Mar 2008, 13:39
