I am using Ulead DVD MovieFactory and I am having a hard time I can make a DVD that will show a menu and then if you client on the menu item it will play from that menu item to the end of the DVD but thats not what I need.
I would like it to go back to the menu after each movie! Can this be done. I dont want my view to pick the first movie and then see all the movies without going to the menu I would like it to show menu, pick a movie, play movie and then return to menu.
also I would like to put a copyright movie in before the menu is displayed. can this be??
@johnpalm
RU dead set on using Ulead DVD MovieFactory, because DVD Lab can do both of the tasks you want to accomplish (Return to menu after movie and an intro video clip) fairly easily...?
I could walk you through it, if you would like to use DVD Lab.
F2k
I don't use Ulead but any half way good DVD Authoring program should be able to do this. You should look for a section that defines the commands, sequence, or last action. You should be able to set the last action of each video clip to goto the main menu.
Again I don't use the ulead products but there's a option for it buried in there somewhere I'm sure. -
How to create a Intro Clip b/4 Menu with DVD Lab
#1 Create a new project (File --> New)
#1.1 Note the four objects in the Connections Window: Green First Play Symbol / Blue Title Button Symbol / Menu 1 / Movie 1
#2 Click Draw Links Icon (second icon down to the left of the Connections Window)
#3 Click on Green First Play Symbol and drag to Movie 1
#3.1 You should now notice a Green Line (Link) between Green First Play Symbol and Movie 1
#4 Click on Movie 1 and drag to Menu 1
#4.1 There should now be a Black Line (Link) between Movie 1 and Menu 1
#5 To have other movies "return" to Main Menu repeat step #4 (i.e. Click Movie 2 and drag to Menu 1, Movie 3 and Menu 1, etc...)
Please let me know if this helps or if you have any more questions...
Later,
F2k
Adding 'copyright' info to video clip in Ulead DVD Moviefactory 6
By colinb1 in forum EditingReplies: 3Last Post: 19th Apr 2011, 08:13 -
DVD Copyright Query.
By CountryFarmer in forum Newbie / General discussionsReplies: 11Last Post: 7th Feb 2011, 02:54 -
Secret Copyright Treaty Leak: ISPs Worldwide to Become Copyright Cops
By joepic in forum Latest Video NewsReplies: 17Last Post: 5th Nov 2009, 11:05 -
Copyright VHS to DVD?
By PeterV in forum Newbie / General discussionsReplies: 4Last Post: 14th Apr 2008, 09:02 -
how to create DVD copyright?
By C-W in forum Authoring (DVD)Replies: 2Last Post: 18th May 2007, 10:17
