Okay here is my problem,
I have an avi file in divx format but it is in 23.967 FPS. Now to get that DVD compatible I have to convert it to 29.967 My question is how do I do this using nandub / tmpgenc with audio/video in synch. I don't want to use besweet to make an AC3 file because it isn't compatible with some pioneer dvd players. I couldn't find this paticular problem doing search and It's getting very late so I thought I would ask this question. If you could help me I would appreciate it very much. Thanks.
Okay,
I did what you suggested. I encoded the move in TMPGenc and selected 3:2 pull down and 23.97 (29.97 internally). Now when I get the end result I authored it and burned it onto DVD -R media (Rigek04). After that I went to play the movie in the DVD player and I get jittery frames. In each frame I notice where it kind of slows down for a second and then goes back to normal. I have also tried messing with the field order (a) and (b). That did nothing. If anyone can help me with this I would appreciate it.
Having problems synching subtitles with VOBs
By somethingcd in forum SubtitleReplies: 0Last Post: 1st Feb 2012, 09:23 -
H.264 Encoding - Sound Synching
By mabus in forum Newbie / General discussionsReplies: 5Last Post: 19th Nov 2009, 11:36 -
Video/Audio synching problems.
By ericblair in forum DVB / IPTVReplies: 0Last Post: 26th Jan 2009, 19:38 -
using xvid4psp, but the video isnt synching correctly...
By Kaminoshi in forum Video ConversionReplies: 18Last Post: 27th Dec 2008, 00:22 -
DVD camera and synching a recording.
By HoustonShea in forum Authoring (DVD)Replies: 9Last Post: 8th Jan 2008, 12:32
