Are there any mpeg formats that TMPGenc cannot open?
It has 'difficulty' opening mpeg-2, but there are several solutions that allow it to. Also many people complain of difficulty in opening xvid (mpeg-4) but with the right settings and codecs this can be overcome.
Short answer - No
Even if TmpGenc cannot open a particular format, chances are it can be frameserved. -
For mpeg 2, what is the easiest program to use - with decent quality - that does this? Final objective is DVD format.
It depends exactly what version of TmpGenc you have. The very latest version I think will open mpeg-2 nativley. Slightly older versions require you to have one of several particular mpeg-2 codecs installed. The PowerDVD codec is one, can't remember the others.
Probably the most reliable way of opening mpeg-2 in Tmpgenc is to use DVD2AVI. Open your mpeg file in dvd2avi, select save project. It will demux the audio and save it in one file, then save a .d2v file, which is the project file. You can then open this .d2v file as the video in TmpGenc, and the audio file as audio input (if you want) and encode from there. Works every time for me.
Not sure about WinDVD, I think it should be OK, check TmpGenc's web page. The TmpGenc history info should tell you which are the supported mpeg-2 codecs.
You can get the PowerDVD codec by downloading the trial version. With recent versions the codec would continue to work even after the trial had expired. Not sure if that is true of the latest but it may well be as the codec is a seperate DLL.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 22:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
