I am capturing VHS video to MPEG2, then editing using Screenblast Movie Studio 3.0. The plan is to next use TMPGenc Author for chapters and burn.
Is there a filter or tool that I should consider to improve the quality of the image?
Originally Posted by vwcrusher
and if you're going to filter it, you might consider capturing in .avi, rather than direct to mpeg.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Originally Posted by housepig
Capture to avi and convert to MPEG with TMPGEnc - it has loads of filter settings and you can set the bitrate exactly to match the destination media.
You might find this helpful:
VHS TO DVD Conversion
Hi8/VHS to DVD: which bitrate do you recommend?Regards,
Rob -
I can't capture in anything by MPEG2 as I am using a Sony Vaio.
The problem is that the image is a bit fuzzy, not clear.
Again, understand it is coming off a VHS tape so I realize that its not going to be crystal clear, I was just curious if there is a tool that can improve the image.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
S-VHS to DVD - with maximum quality
By Tafflad in forum Capturing and VCRReplies: 5Last Post: 23rd Nov 2009, 05:29 -
VHS -> DVD question on quality.
By Oob in forum RestorationReplies: 9Last Post: 18th Apr 2009, 23:40 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43 -
How to get DVD Quality on a VHS Transfer?
By Nitro89 in forum Capturing and VCRReplies: 28Last Post: 10th Nov 2007, 00:26
