  1. Iīm having a weird problem with Nero 6. Iīve burnt several DVDīs with it but a few hours ago it started showing error dialog boxes concerning cache.
    With the smaller filles of the VIDEO_TS folder there is no problem, the trouble is with the big .VOB files that arenīt correctly added to the compilation - it adds the file but itīs not really there.
    Iīve checked the cache settings and itīs the usual: itīs going to user - local sett - temp.
    Anyone care to coment?
    J
    Dec 2002
    Make sure your not running Norton System Works. It never deletes anything and fragments your HD very quickly.
    Make a folder in C drive called TEMP. Point Nero's cache to c:\temp and make sure it's empty between burns.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
