Hi,
Can anyone recommend a good fire-wire card to be used with a Canopus ADVC-100?
I currently have a Dell machine, and a Texas Instruments firewire card, and as a result the Canopus ADVC-100 is not working with it.
The Dell machine has been rebuilt a number of times, and the ADVC100 does work.
I have read about the incompatibility between TI cards and Canopus ADVC100's.... if this is correct, can anyone recommend a good replacement?
Thank you
I bought a Koutech Firewire card from NewEgg and didn't have any problems with my ADVC-100 working in Windows XP. This card has a Ti chipset. Canopus has said that the Ti chioset problem should be a nonissue now because newer Ti chipset cards do not have the problem anymore.
Hope this helps.
Mythos -
I forgot to mention that I'm on Windows 2000... does that make a difference to any card recomendations?
With regards to last post.... does that mean that any new TI cards will work with the Canopus ADVC100?
Thanks for your help -
No Problem. A far as I know, any new Ti chipset cards should work. Windows 2000 should also be fine. You can double check by going to the forum on Canopus' website at http://forum.canopus.com/
My card had really good reviews on NewEgg. It comes with Ulead VideoStudio 7 (I don't use it though) and a firewire cable. It also has a 5 year warranty. The stickers on the box say designed for Windows 98 through 2000 Pro. I'm having no problems with XP either.
My card is actually called the IOFLEX-FW4 and is manufactured by Kouwell. The website for support is listed as Koutech and NewEgg listed it under Koutech as well. The model number is: KW-582V2
One other note is that my motherboard has a VIA chipset which is supposed to be notorious for incompatibilities. I haven't had any problems so far.
I hope this helps. I really like the my card, but I know there are probably ones out there that are better. Mine is straight firewire with no USB connectors. I know some people like the combo cards like that, but my motherboard already has both USB 1.0 and 2.0 connectors.
Good luck.
Mythos
Recommendations for a Video Card
By bryankendall in forum ComputerReplies: 6Last Post: 25th Feb 2010, 16:15 -
Need recommendations re. AGP card(s)
By CBinSD in forum Newbie / General discussionsReplies: 14Last Post: 14th Aug 2009, 20:20 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19 -
Video Card recommendations
By Seeker47 in forum ComputerReplies: 13Last Post: 26th Jan 2008, 01:36 -
Recommendations for capture card?
By Big Chupa in forum Capturing and VCRReplies: 6Last Post: 12th May 2007, 21:24
