I just bought the LG GSA-4040B. Firmware updated to A301. Burn DVD-R & -RW no with problems. Had one success with DVD+RW but no go for DVD+R. I have tried 3 times now and everytime a coaster. I know the files are correct as I burned them on a DVD-R and they work fine. I use DVD De-crypter for ripping in file mode, DVD clone to convert files to 1 disk size and Nero 6.0.0.0 for burning. I have a Elta 8882 which plays just about anything and people have said it has no problem playing DVD+R (it plays DVD+RW). Also, just tried to burn one with DVD Clone and still no-go.
Anyone have an idea................................
Can you be more specific ? What's exactly the problem with the DVD+R
disks you burnt ? Are they totally unreadable or is it just the end
of the movie that you can't play ? You said you had trouble
reading them on a standalone player, but can you read them on the PC ? -
They are not readable on my player as well as both of my computers. As I have said, the same files have been burned on DVD-R & -RW with no problems. I'm going to +RW again and a Phillips +R ( the other +R media were TDK, EMTEC and Sony). I guess I will have to keep trying different authoring programs and media. If the discs were not readable on my player but were OK on the computer I know it would be a player problem. When the +R are burned with Nero it says that it was successful (each disk is verified as well). I hope that helps.
Now that I come to think of it ... I remember reading somewhere that
the early versions of Nero 6 had problems burning some types of
DVDs (I can't remember if it was DVD+R disks). The disks weren't
finalized properly or something like that.
I suggest you try the following: Try creating a correct iso image from the
VIDEO_TS directory using ImgTools Classics (it's free). Then, try
burning the iso image to a DVD+R disk using the iso-write mode in
DVD decrypter (this tool is also free).
If it works, then you definitely have to upgrade your Nero to the last
version.
Dvd burning problems and frustration
By zubiri in forum Authoring (DVD)Replies: 14Last Post: 27th Sep 2010, 21:19 -
Problems burning DVD movies
By No Idea Newbie in forum DVD RippingReplies: 7Last Post: 13th Jul 2009, 04:18 -
DVD burning problems
By Tbag in forum ComputerReplies: 13Last Post: 3rd Sep 2008, 16:55 -
DVD download Burning problems
By completeidiot in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 06:53 -
By ssaamm in forum DVD & Blu-ray WritersReplies: 10Last Post: 22nd Sep 2007, 01:11
