Hi. I just downloaded some DivX movie, but there's running timer in picture all the time. But I saw in some other movies, that it can be improved by blurring that part, so the blurred portion fits well into sourrounding area. Luckily the timer doesn't touch the top black frame, so I think the process is achievable. Would you recommend me some good VDub filter to do this, or direct me to some tutorial ? Thanks.
You need logoaway or delogo or something similar - all VirtualDub filters.
Have a look at the VirtualDub tools section.
If your counter is within the 'black borders' of letterboxing etc.. you should be able to remove it totally, by simply covering it up with a black (or dark grey) box.
cheers,
mcdruid.
brighten only a portion of a video?
By magnumpy in forum EditingReplies: 1Last Post: 23rd Dec 2011, 00:00 -
SONY DVP-SR700H - squashed DivX picture
By jhrebacka in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Nov 2010, 10:21 -
mkv to divx, picture transition not smooth
By chosen1 in forum Video ConversionReplies: 4Last Post: 28th Jan 2010, 06:02 -
Resize Divx/Xvid For Portable With VDub: Artifacts/blur
By gordonliu in forum Video ConversionReplies: 6Last Post: 4th Apr 2009, 08:42 -
Removing more than one portion of a video at once.
By M Bruner in forum EditingReplies: 2Last Post: 21st Nov 2008, 04:17
