some disks won't let me extract the files
so far Finding nemo and PoolHallJunkies doesnt work. I get an error that says: "Failed to decrypt video title set 3" or set 2 (depending on the disc) if i choose skip, then i can't watch the movie. Not sure if different mac sofftware would rip better? so far 50% of the dvds i tried have worked (2) and 50% have not (2). I wonder if this program is only able to rip 50% of dvds.
The reason you get that error is because some of the new disc encrypt the title menu (in the case of Finding Nemo, the THX Audio Menu is encypted and just happens to sit right before the movie.) and some of the other menu's are encypted in more than one location. This is more common on discs that have animated intrances before the title menu. The current release of DVDBackup (1.3) does not support for decrypting of those types of menus yet. There is a workaround, however. What I did to make a backup of mine is that I used DVDBackup and pressed skip when prompted. Then, I used DVD2OneX to extract the movie (the actual movie is decrypted, only the title menu is still encrypted) and make it a standalone movie. Worked fine. DVD2OneX is listed in the tools section and can be purchased for about $55-60 USD from http://www.dvd2one.com. Good investment, if you ask me. Hope this helps.
Reg -|- Tezgno
Extract Video files from DVD
By thumpy in forum Video ConversionReplies: 3Last Post: 20th Apr 2010, 23:37 -
Extract Audio from DVD Files
By foochuck in forum DVD RippingReplies: 7Last Post: 19th Jan 2010, 05:11 -
Easiest method for Mac (Leopard) DVD backup?
By derrek.mcnab in forum MacReplies: 15Last Post: 12th Mar 2008, 20:30 -
Error on backup hd-dvd 1.0
By kulmagen in forum DVD RippingReplies: 6Last Post: 7th Feb 2008, 13:08 -
I need to extract photo files from DVD
By tejana in forum MacReplies: 4Last Post: 17th Aug 2007, 16:31
