Hi everyone,
I am a total newbie to all this burning stuff and I have just bought myself a Lite-On DVD Burner... I am making a movie with some friends of mine and I have edited it using Adobe Premiere... Now, how do I take the edited movie and transfer it onto a DVD-R that is watchable on my Sony DVP-S530 DVD Player... I can't even find the edited movie file except for the project file... Basically I don't know what format my edited movie is in and the only way I know how to get to it is by opening Premiere and opening the project... I need some serious help please! I am totally new to all this...
-merc
Closed Thread
SYSTEM SPECS:
: Abit NF7-S v2.0:
: Corsair 512MB XMS DDR3200 :
: AMD Athlon XP 2600+ at 2.01 :
: 80 GB WD HDD 8MB Cache :
: Antec LANBOY Case 350w PSU + 2 80mm fans :
: Sapphire ATI Radeon 9800 Pro 128MB :
: LiteOn 4x DVDR/RW :
You're gonna have to learn how to crawl before you can run..But i'll push you in the right direction...
First of all, your project file holds all the links necessary from your edited video. That way Premiere doesn't have to load your actual movie file into itself..When you make a transition, temporary files get stored, and those files are used for timeline export.
Secondly, when you do finish all your editing, transitions, etc., you need to export it to MPEG2 format.
IF you have 6.5. then there's a built in encoder. Simply go to File>Export Timeline>Adobe MPEG ENCODER, and choose the correct settings.
Might I suggest reading up on the project settings, and understanding MPEG2 for DVD authouring...
Finally, authour your compilation..I personally enjoy DVDLab....
Good luck!!
Please don't cross post.
https://www.videohelp.com/forum/viewtopic.php?t=190257
Compress movies in Adobe Premiere the same as Windows Movie Maker
By ckeen in forum Newbie / General discussionsReplies: 4Last Post: 13th Jun 2012, 21:11 -
preparing video clip for editing in adobe premiere and burning to a dvd
By namreeb808 in forum Newbie / General discussionsReplies: 3Last Post: 18th Feb 2011, 00:13 -
Vegas Movie Studio Platinum Pro Pack vs Adobe Premiere Elements 8
By bowmah in forum EditingReplies: 6Last Post: 27th Jan 2010, 21:15 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 04:17 -
Adobe Premiere Pro & Burning DivX
By epsilon9090 in forum Authoring (DVD)Replies: 9Last Post: 22nd May 2007, 16:42
