What is the Deinterlace filter in TMPGEnc for? Do I need to use it if I'm ripping an interlaced VOB from a DVD and converting it to an interlaced SVCD for display on a conventional 4:3 TV?
Nope. No need to De-interlace unless your TV and DVD player supports progressive scan. While many DVD players do support progressive scan output, most conventional TV's do not have progressive inputs.
If you were to play it with a PC and view it on a PC monitor -- then de-interlacing of an interlaced source would be required as a PC/monitor is a progressive scan device.
Rule of thumb ...
Capture Interlaced/Deinterlaced according to the source and encode Deinterlaced/Interlaced according to the viewing device. Since the TV is interlaced -- do not de-interlace.
Definitions:
Deinterlace: https://www.videohelp.com/glossary#Deinterlace
Interlace: https://www.videohelp.com/glossary#Interlace -
Originally Posted by Ripper2860
Thanks.
Deinterlace Region 4 DVD
By StaticSense in forum DVD RippingReplies: 8Last Post: 22nd Jul 2011, 13:54 -
Playing Video on display 2 and display 1 goes black
By sidewaysdriver in forum Software PlayingReplies: 2Last Post: 3rd Aug 2010, 00:36 -
hdv/dv to dvd: to deinterlace or not?
By arod0405 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2009, 09:07 -
deinterlace miniDVD and miniDV material before (re)encoding to DVD or not?
By Massa in forum Video ConversionReplies: 3Last Post: 2nd Jan 2009, 13:54 -
DVD to WMV 9 with WMA 10 5.1 Surround Sound - Deinterlace or Not???
By JBredensteiner in forum DVD RippingReplies: 3Last Post: 7th Nov 2007, 10:32
