I have 9.98(Roughly 10gb) of dvd mpg that i want to put on two dvds.
Should I
1) Make 1 dvd 4.7gb and shrink the rest(5.28gb) to 4.7gb using DvdShrink.
2) Go all out and make the entire 10gb to 4.7gb to fit on 1 dvd.
P.S: Will the quality be heavily dropped if i use either method?
shrinking the full file to one disk is going to really cut down on quality. I'd split it in half and shrink each part just a little bit to fit on a disk so you have minimal loss to both parts.
Greetings,
For what it worths:
I would try different compression softwares like instantcopy, nero recode, etc and compare the quality. When I back up dvds and I really care about the quality, I always do tests and I found out the output quality can vary a lot. Sometimes, it may be excellent with Instantcopy and bad with dvdshrink. Some other times, it can be exellent with dvdshrink and bad with nero recode.
I found out Instantcopy is not so good with high compression but dvdshrink has a lot less blocs than instantcopy.
Thank you
dvdshrink
By Faerel in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2010, 23:07 -
Problem with DVDShrink
By abba1961 in forum DVD RippingReplies: 3Last Post: 22nd Mar 2010, 01:52 -
dvdshrink for bluray
By xenotox in forum Blu-ray RippingReplies: 20Last Post: 18th Jul 2009, 09:10 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Once I've used DVDshrink, then what?
By craniac in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 17:17
