Can any tell me how to fix the following (see attached) error using DVD Decryptor the beginning of its burn process.
Steps:
1. DVD Shrink,
2. then IMG tool
3. then DVD Decryptor
Once DVD Dcrytor begins it will buffer to 100% then will the write retry will count to 20 sec, then the error will popup, so I click retry, then another 20 secs counts, then error, then retry. only then will the DVD start to burn. Any help would be appreciated.
We need more info:What does the DVDDecrypter error say?Are you using the latest version of DVDDecrypter?Have you enabled DMA in Device Manager?
This guide is for ripping but it might help: www.dvdrhelp.com/forum/viewtopic.php?t=182913 -
Moviegeek,
I attacheded the error message and I reviewed the thread you had in your reply. The instructions do not apply to WIN XP, can you help? I've at least made the changes in DVD Decryptor but still no change.
Copying DVD's with Shrink and decryptor
By LeeRobertE in forum DVD RippingReplies: 6Last Post: 26th Feb 2011, 14:46 -
DVD Decryptor with newer protection schemes?
By Huh...What? in forum DVD RippingReplies: 7Last Post: 26th Aug 2010, 08:34 -
DVD Decryptor Error Massage
By pchan in forum DVD RippingReplies: 13Last Post: 18th Jun 2009, 13:37 -
Usinf IFOEdit to correct an error in authoring
By netmask56 in forum Authoring (DVD)Replies: 3Last Post: 30th Nov 2007, 22:30 -
SONY AW-Q170A Ripping tops out at 3x with DVD Decryptor
By alwayssummer in forum DVD & Blu-ray WritersReplies: 3Last Post: 29th Oct 2007, 18:08
