Im converting a movie that i think is MPEG to go on a DVD. I used 4 programs in this order. I used VDUB, then TMPEG, the BeSweet GUI, and also TMPEG dvd author. When i was done doing the encoding and played the DVD the sound started off good but progressivly the timing got worse and worse throughout the movie. I would aprreciate any input you may have on this topic, thanks.
Results 1 to 14 of 14
sorry i cant get the screen shot to work but heres exacly what it says
Force imput Sample Rate (checked)- 48000 -
i wouldnt check that if your source is 44.1,it really screws up things,i use goldwave to convert the file to 48 khz then use besweet.if you converted the file to ntsc then you would have the convert 25fps to 23.976 selected.Also if you use tmpgenc to encode use `do not framerate conversion` should be checked in settings/advanced and ntsc film selected.
im not encoding from pal to nstc. Im just trying to put a regular movie that i downloaded on to a disk.
Okay, if it's downloaded, and you opened it in Vdub, chances are that it's an .AVI, and not MPEG. Also, chances are, that we have to correct the audio first of all...
Now, within Vdub, go to File>File information, and tell us what video codecs, and what audio codec and samplerate (KHZ) is listed....
FYI, since DVD requires 48000, most people tend to save out their downloaded audio, from its' original 41000hz, and resample to 48000hz. This can be done by either Vdub, or an outside audio editor, like Goldwave or Cool Edit.....Most stretch errors happen because people don't take the extra step to convert the samplerate....
Good luck..... -
You`re not giving enough info,im trying to ask what type of encoding you are doing.
video- 23.976 fps
decompressor- divx pro 5.05 codec
Audio- Compression- Fraunhofer IIS MPEG layer 3 codec
Sample rate- 44100hz
And Johns0 i dont really know what you mean by what type of encoding, im really a newb, all im trying to do is convert an avi file that i downloaded to go onto a dvd-r -
https://www.videohelp.com/divxtovcd.htm
Basically, follow these steps. Step three of audio extraction should be 48000hz, since it's DVD you want.
When you open up Tmpgenc, load the saved .wav into audio stream, and load the Divx File in the video stream.
I'm assuming you can take it from here for Tmpgenc. Instead of the VCD templates, you'll need to look at DVD Film.
Read up the encoding guides..
Good luck!!!!
Play a video at 8x with sound?
By blud in forum Newbie / General discussionsReplies: 23Last Post: 5th May 2012, 21:40 -
VOBs burned to DVD have sound missing on TV (but play OK on PC)
By martinlest in forum Authoring (DVD)Replies: 3Last Post: 29th Mar 2012, 06:17 -
MPC wont play sound when watching DVD
By Anonymous1 in forum Software PlayingReplies: 1Last Post: 18th Oct 2011, 07:52 -
mpg with sound that doesn't play
By sivodsi in forum Newbie / General discussionsReplies: 3Last Post: 13th Jan 2010, 08:38 -
DVD player does not play sound anymore
By M_W in forum AudioReplies: 4Last Post: 9th Sep 2007, 04:20
