I'm burning coaster after coaster (compusa/princo dvd-r) using DVD Decrypter or DVD Shrink + Nero/Copy ToDVD. Some will play on my Apex 1500, but almost none will play on my older Panasonic RV30.
I've read the post (https://www.videohelp.com/forum/viewtopic.php?t=127624) about adjusting Nero for UDF 1.02 support in older players. No luck. I was experimenting with ImgTool and a message came up with a warning about Volume names longer than 8 characters.
Could this be my problem? Or should I just get different media. The compatibility guide stated that the Panasonic RV30 reads DVD-R, so I didn't think that was it.
TIA
My advice is:
1) Keep the volume name short. I see no reason to name it in the first place.
2) Get some higher quality media (Maxell, Memorex, Ritek) Cheapo media can cause all sorts of problems. An inability to play in some players is only one of them. Princo is the most mentioned name in the forums in regards to problems with cheapo media.
3) Follow a guide and make absolutely sure you are doing everything right. A seemingly minor mistake can prevent you from making a viewable DVD. -
Also if you are making coaster after coaster it may be worth investing on a couple of rw's so you can test your creation before you make a final burn (should save you some pennies)
The two most common reasons for DVDR failures besides bad media is.
1: Failure to put all the DVD complient files into a "VIDEO_TS" folder then burn that folder.
2: Not finalizing the disc. -
Originally Posted by Bob W
3: cddvdrecordables.com media to that list (I think that was the sites name)
and point out we are talking about PRINCOs here. -
Thanks ror everyone's replies.
Or wrong?
Originally Posted by flaystus
I will try the better media to sort out the problems though. Any more thoughts?
Thanks.
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 08:08 -
Sony trv 18 no internal speaker volume, no headphone volume
By websbymark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Oct 2009, 11:39 -
Looking for easy tool to get length of a DVD
By lcluster in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jan 2008, 19:01 -
Image PPI -> DVD slideshow...does it matter?
By Grunberg in forum Authoring (DVD)Replies: 1Last Post: 12th Nov 2007, 17:06 -
DVD to ipod sounds like a chipmunk no matter how I convert
By nukular in forum ffmpegX general discussionReplies: 3Last Post: 11th Sep 2007, 18:00
