i have a dvd ram with a home movie on which i would like on a dvdr
is there any software i can get to convert this???
my dvd rom luckily plays the ram ok but i dont understand the files on the ram disc
cheers for the help
Yes, you can. But, please do "a little search" before posting. This issue has been discussed many times and there is a LOT of information on that on this forum and lots of other places.
You might want to start with TMPGenc DVD Author or Ulead MF2 ( I prefer DVD Author). -
ok
after several days ive tried a "little searching" and found nothing
is that why your post count is so low because you constantly do a "little searching" rather than join in debate on here??
where should i do a "little searching" - because i still cant find a thing -
Copy the main File from the DVD-RAM (The Largest One) to your Hard-Drive..... Rename the file extension of the aforementioned copied file to 'mpg'....... Download the TMPGenc DVD Author software (Tools Section - This Site) - Add the Video file (The One copied from the RAM DISC which should now have a file extension of 'mpg' into TMPGenc DVD Author - set your Chapter points etc. etc.... create DVD disc (With DVD Author) and Burn away using the same software.
Hope this helps
Matshita DVD Ram UJ851s not recognizing blanc dvd
By ezradallas in forum ComputerReplies: 7Last Post: 12th Mar 2010, 11:50 -
Converting DVD-VR (DVD-RAM) with Multiple Tracks
By alexs77 in forum DVD RippingReplies: 2Last Post: 26th Dec 2009, 03:27 -
HOW to DVD-RAM on PC so that it plays in my PANA DVD Player
By saxon22 in forum Authoring (DVD)Replies: 21Last Post: 18th May 2009, 07:34 -
dvd recorder with dvd-ram, no hdd, gemstar tv guide, atsc or ntsc tuner.
By 84transam in forum DVD & Blu-ray RecordersReplies: 4Last Post: 5th Nov 2007, 19:55 -
DVD-RAM from Panasonic ASTC recorder to PC for DVD authoring?
By Philbiker in forum Capturing and VCRReplies: 2Last Post: 30th Oct 2007, 17:42
