  1. how would i make 4 .vob files into one big one? is it possible?
    canada
    you can load them in v-strip and make a single vob,any reason you need a single vob?
  3. It is possible with DVD Lab 1.3 >b3 I believe
    I have b7 which has 30 d trial .
    Simply import the first vob in assets en u will be asked 2 join or directly use vob --> choose join
  4. Use VOBMerge 2.
    Download Here
    Its real simple.
  5. If the vob's are on media. use dvddecrypter. On one of the tabs for settings it says something to the effect of one big file.
  6. Member jaxxboss's Avatar
    Apr 2003
    JAX, FL
    I think it say "ONE BIG HONKING VOB"
  7. Member zzyzzx's Avatar
    Baltimore, MD USA
    Originally Posted by Turtle49
    Use VOBMerge 2.
    Download Here
    Its real simple.
    I also recommend VOBMerge.
