  1. I'm using Tmpgenc long time for converting movies to VCD.
    Well today i have uninstalled some of codecs and filters and the problem accured. Till now tmpgenc had no problems with converting AC3 now it says: the error acured while ACM intialized.
    Have any clue which codec or filter i need to reinstall.
    CYA!!!!
  2. Huh? As far as I know TMPGEnc has never supported AC3 audio. When was this added? What were you doing with AC3 in TMPGEnc?
    vcddude
  3. Member wulf109's Avatar
    Jul 2002
    For reasons I don't understand TMPEG 2.52 will encode ac3,it will even open vob files and convert them. I have several versions of TMPEG on my computer,but I make a point of keeping 2.52 because it opens ac3,older and newer versions will not.
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    I usually just extract the AC3 to wav with Goldwave and use that as the audio source.
    Toronto, Canada
    I use TMPGEnc v2.59 Plus, and I have no problems opening and converting files with ac3 codec. As a matter of fact most of my files are ac3 audio.
