I have gotten so far now and I pretty know the most I need to know to make a perfect backup,,, just one thing I recently started with is to import srt subtitles downloaded from DivX subtitle sites.
I must be having troubles when converting it through Srt2Sup, I donīt seem to know the correct settings. I obviously need to have the Global Setting checked cus oterwise I need to unchech ever line and it is about 1000 lines.... I have tried to play around in the Global settings and in the final author I get transparent charachters with red outlines. Doesnīt matter what I change the code to in the IFO file cus the character will stay transparent. The transparent box wasnīt checked in the Srt2Sup program, only for the background it was checked. I did try once unchecking the transparent box for the background and the background came out in the final product. well well....
how do I set it with Srt2Sup.... I have the latest version.
thanks
Hi,
You say you have the latest version is this a4.03?
The subtitle colours are stored in the IFO file, however transparent is saved in the SUP file.
Srt2Sup a4.03 gives you the settings you need to enter in the IFO file to make sure that the colours in Global settings match what you want on the DVD.
Regards
Srt2Sup -
Hi creator
and yes I did that... used the color info and set those in the ifo file.... but but but.. and here is a big but...
The background color must be black, at least for me,, even if the box transparent is checked it has to be black. When I had it in white the text became transparent. Only the outline colors I could change....
I think this is worth mentioning cus no one else seemed to know
very good program tho
How to keep subtitle text from looking ragged in final disc image???!!
By wildgeese in forum ffmpegX general discussionReplies: 8Last Post: 24th Feb 2009, 14:40 -
DVD Subtitles (srt2sup) not working! What to do?
By panderson in forum SubtitleReplies: 3Last Post: 11th Jan 2009, 06:10 -
how to insert subtitle in Final cut pro 4??
By yunakokimama in forum SubtitleReplies: 0Last Post: 12th Dec 2007, 17:16 -
Srt2Sup - new line within subtitle problem.
By mattstan in forum SubtitleReplies: 3Last Post: 17th Sep 2007, 13:18 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
