When i make Mpeg1 VCD with TMPenc at VBR and burn it with Nero as VCD all is ok on my computer but on my pionner DV 535 i have problemes whith sound that is not correct.
it sems that all is ok at CBR but not with VBR.
Could u help me?
Some players have problems to play XVCD. Did you make sure, the audio sample rate is 44100kHz ?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
yes the rate is at 44100kHz but i thought that Pionner DV535 was ok with all format
A transcoder for some high video bit rate conversion.
By stevyL01 in forum Newbie / General discussionsReplies: 5Last Post: 25th Mar 2010, 14:09 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
Alright, what IS the big deal with variable bit rate recording?
By ministry88 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 1st Jul 2009, 17:26 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 11:26 -
What is a good software to encode variable bit rate MP3 files?
By jbitakis in forum AudioReplies: 5Last Post: 24th Jan 2009, 15:58
