Using DVDShrink, I re-authored a foreign movie and took only the movie. It worked fine!! Next I used Nero (DVD-Video) and copied all the files to the video_ts directory. The message states that VTS_01_1.VOB is greater than 2GB and that the ISO format cannot write this, only the UDF format can.
I then tried DVD-UDF instead of DVD-Video in Nero and all seems to work except that it says it is not compliant to play on DVD-Players.
Any help for a newbie would be greatly appreciated!
Mike
You shouldn't have a VOB greater than 1 GB. Did you rip the movie first with DVDDEcryptor? Don't uncheck the box that says 1GB VOBs.
You shouldn't ever have this problem unless you pre-rip the movie and force it into a non-standard VOB pattern.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Strange burning issue with DVDShrink/Nero combo
By RoyGBiv-inRI in forum DVD RippingReplies: 7Last Post: 7th May 2010, 11:00 -
Problems Burning Discs with DVDshrink/Nero
By iownju in forum DVD RippingReplies: 5Last Post: 20th Jul 2008, 15:56 -
I have a question about burning avi files to dvd...
By amcardwell in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2008, 15:07 -
Nero automatically ordering after burning files
By ToYo in forum Authoring (DVD)Replies: 5Last Post: 1st Nov 2007, 03:05 -
Can DVDShrink be set to use ImgBurn for burning?
By RoyGBiv-inRI in forum DVD RippingReplies: 7Last Post: 21st Jul 2007, 13:17
