hi, ive just bought a liteon dvd writer, and i got this programme call sonic mydvd, as anyone used this, is it any good...?
"I know it seems hards sometimes but remember 1 thing, though every dark night there's a brighter day after that, so no matter how hard it get, stick ya chest out, keep ya head up and handle it"
"politicians and hypocrits dont wanna listen" -
This program came with my Sony DRU-500a. The DVDs that I used this program to author played fine and the quality was fine. HOWEVER, Sonic MyDVD always insists on reconding all audio back to PCM, which greatly reduces the length of the movie you can get on a DVD. Also, it takes (depending on the speed of you computer) up to an hour to reencode the audio. While the final result is acceptable, Sonic MyDVD (in my opinion) unnecessarly wastes space and time by reencoding the audio to PCM.
I agree with rkr1958. You sacrifice video quality for audio file size by using Mydvd. If your encoded mpg file size is too big, it won't even let you author it.
I use Ulead DVD Movie Factory to author and burn directly to disc, fast and generous file size. If the file is too big to fit on a disc then I author it to a VIDEO_TS folder, then use DVD2ONE or DVD95COPY to shrink it down to fit on a disc then burn.
Roxio MyDVD menu display
By moviegeek71 in forum Authoring (DVD)Replies: 1Last Post: 15th Oct 2008, 22:03 -
Why cant i change audio output in MyDVD 10
By LiBiDoXP in forum Newbie / General discussionsReplies: 0Last Post: 14th Jul 2008, 02:16 -
sonic vegas
By m baqar in forum Authoring (VCD/SVCD)Replies: 1Last Post: 2nd Apr 2008, 02:29 -
large file size when importing small video clips into Sonic MyDVD
By artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 20:48 -
Limited background Audio in MyDVD 9
By cmblocker95 in forum Authoring (DVD)Replies: 0Last Post: 6th Jun 2007, 16:21
