Hi everyone...
I try to load AVI file into VirtualDub. I keep getting this :
"One of the video codecs installed in the system modified the video format passed to it by VirtualDub. This indicates a codec bud that may cause the windows video codec system to malfuntion."
What does this mean and how can we correct this ???
Thanks in advance
Smells like the Nemo Codec pack? Or DivX 3.11 .
What codec does the AVI actually use? What's the 4cc header say.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
When I load it in VirtualDub and check file information, it says the video decompressor is APvc, I found the codec...still getting the same pop up window (Should I reboot the machine after installing a new codec ???)Originally Posted by Gazorgan
As for 4cc, I have no idea what that is..where do we check that ??
Thanks for helping
p.s. Where can I find the Microcrap codec ?? Been searching the net without any success
Episode 6 Bug? Or Quicktime Player 7 bug?
By NY2LA in forum Video ConversionReplies: 3Last Post: 25th Jun 2012, 16:59 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
bad codec or bug maybe?
By barnfly808 in forum Software PlayingReplies: 4Last Post: 23rd Dec 2008, 00:21 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
Possible Bug?
By CurtisMinBC in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 25th Jul 2007, 03:55
