    Nov 2003
    Northern VA
    If I were to capture video from DV tape (in the DV camcorder), via a 1394a/Firewire card, onto my computer in DV Type 1 or 2 format, would they be in the exact same format? That is, would both formats have the same video bit rate, audio bit rate, aspect ratio, etc?
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    it should - a DV "capture" isn't a capture at all, it's a transfer of data - the capturing (digitizing of analog source) has already been done by the camera.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
    Nov 2003
    Northern VA
    it should
    Anyone with a more definitive answer?
    Oct 2003
    All your doing is transferring the DV your camera already "encoded" to your PC.
    The data is fine. And is exactly what your camera "took."
    Now, what you DO with that data is up to you.
    Programs will use an installed CODEC to view the data. The quality of that CODEC may play a part, but the audio/video is bit for bit as your camera captured it.
    No Decode/Encoding it/has taken place on the simple transfer.
    Stereo, 48Khz, 16bit (16 bit, right? Or is it 32 bit float? Hmmm...)
