What would you guys recommend as the easiest / simplest way to copy a dvd and have the resulting dvd have no menu (just play) or have the menu but default to playing?
the dvd is not copyrighted material, so that's not an issue.
the dvdxcopy hack would work fine and is only '5 mins' but is still a bit of work...can you guys think of anything easier? any tool would be up for grabs...
"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
I always use DVDShrink. There is a web page with very easy to follow guides on how to use the program. You can find it here: http://www.dvdshrink.info/guides.php. I always do what you are talking about. I really hate how newer DVD's have the FBI and 'the views expressed...' menu's that you can't skip.
Thanks to DVDShrink, my backups don't have any of that garbage.
- Mattdj matty b -
I use DVD Shrink for all of my ripping as well; however, I dont think that it is what you are looking for. If you are looking for something really easy, then DVDXCopy is as easy as it gets. What version are you using... the Express version automatically gets rid of the menu for you and its literally a one button program. But, if you've already tried it and don't like it then I suggest you try this link:
http://www.dvd.box.sk/index.php?pid=dvdr_soft&prj=list
Lots of different freeware and trial programs there... that's where you'll find the one you want. -
guys - thanks - dvd shrink worked great - same content w/ o the menus .. just what I needed...thanks again...!!
What is the easiest way to determine if a DVD is copy-protected?
By vladorlok in forum Newbie / General discussionsReplies: 16Last Post: 30th Jul 2011, 21:23 -
How to copy DVD 9 to 5 with menu & extras using DVD2ONE.
By BarryHL in forum User guidesReplies: 145Last Post: 24th Mar 2011, 08:36 -
Best & easiest way to clone a dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 30th Jul 2010, 09:00 -
Fastest & easiest way to convert files from dvd to upload to Youtube?
By scarypoultry in forum Video Streaming DownloadingReplies: 2Last Post: 6th Jul 2010, 02:49 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
