I am using DVD shrink to rip the disc, and then I open NERO burn DVD video and drag the files from my dvd shrink directory into the VIDEO folder on the DVD burning menu. I burn the disk and It will work in computers but not standealone DVD players. I have burned them at 2x and 4x, I was using some cheapy 4x DVD-R so I tried hp dvd+RW discs and those don't work either. Please help
Results 1 to 12 of 12
Did you make a empty AUDIO_TS folder? Some standalone dvdplayers need that folder.
The easist way is to use NERO EXPRESS. NERO makes the AUDIO_TS and VIDEO_TS for you. Since I use it, no problems at all and all the standalone dvdplayers plays the backups without any problems. -
I'm having the same problem. Previous burns worked fine on my stand alone DVD player. My latest attempt has failed a dozen times. I've tried using Ulead, TMPGEnc Author, and DVD Shrink..and burned with Ulead, Roxio and Nero. The results work fine on the PC but I get a No Disc message on my DVD. Could it be DVD Shrink that's the culprit? I compress 5 gb to 4.3...
yes there is an empty audio_ts folder. that and the video folder are both made by nero automatically, adn then i drag my files into the video folder, and burn it. it works perfectly fine in pcs but not it dvd players.
try using image tool classic to create an .iso file from the ripped DVD files, and then burn with nero or DVD decrypter.
"Nothing is True, Everything is Permitted" -
Does your player support DVD-R? You can't assume it does.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
what writer, computer, version of Nero, type of media, etc are you using? giving all your system specs makes things a lot faster for us to answer.
thanks for your help guys, the DVDCLone works for me. I have no idea why nero didn't, but i really don't care right now. thanks
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
Samsung Blu Ray Player BD P3600 inconsistent in playing back copied DVDs
By ibramson in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Nov 2009, 18:36 -
have a question regarding playing back mini dvd-r's on my PC
By Bamahusker in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 20th Aug 2009, 00:42 -
dvd player vs dvd recorder for playing back dvds
By JCWagener in forum Newbie / General discussionsReplies: 5Last Post: 14th Mar 2008, 17:50 -
DVD Extras Not Playing Back in Standalone
By SamNZDat in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2007, 04:29
