I converted an high resolution AVI (640 x 480, 40 min about 700MB) file into MPEG2 using Mainconcept Encoder. Then took the video stream and compressed 15% out of the original file size (about 1.6GB) via Rejig.
The MPEG2 did not show any blocks on my computer. But when I burnt it to a DVD-R and viewed it on my standalone player, I got many tiny square blocks for motion scenes.![]()
Since the MPEG2 looked good on my computer, I have deleted everything so it is not possible to repeat any tests. I just wonder whether it was the MC Encoder or Rejig that are the cultpit for the poor quality?
Does anyone has similar experience?
I use Rejig because from my experience with DVDShrink, compressing using transcoding, particularly 10 - 15% does not affect too much about the quality. But lowering the bitrate certainly does. Maybe my logic is wrong.
Has anyone compare the 2 scenarios for the same file size:
1) Encode with high bitrate and then Rejig
2) Encode with lower bitrate -
DVD at high bit rate - Blocky & grainy on big screen
By nharikrishna in forum Authoring (DVD)Replies: 8Last Post: 27th Oct 2010, 03:46 -
How do i use rejig?
By snafubaby in forum Capturing and VCRReplies: 6Last Post: 23rd Aug 2010, 03:42 -
Rejig
By didikai in forum Newbie / General discussionsReplies: 5Last Post: 22nd Aug 2010, 07:21 -
Rejig crashes - where to find old version?
By fk in forum Authoring (DVD)Replies: 2Last Post: 28th Sep 2008, 08:18 -
Rejig crashes during transcoding
By bmwracer in forum Newbie / General discussionsReplies: 10Last Post: 16th Mar 2008, 01:09
