I have an AVI file that was encoded at 20fps using MS Mpeg4 codec. It plays fine and the quality is pretty good.
I used DVD2SVCD and CCE 2.5 to conver to SVCD mpeg and while the quality of the video is great -- you can tell the video is running a little fast and the voices are higher pitch and faster -- although in sync with video. I am sure it was probably the fact that it re-encoded at 29.97 FPS (NTSC). If I use TMPEGenc w/NTSC film the situation is better but the video and audio are not quite in sync.
I wish to play this file as an SVCD on an NTSC TV. Should I / Can I convert the AVI so that the resulting MPEG is also at 20FPS? Would it play on my TV via a DVD player? Any suggestions on the best way to accomplish this? Is there a tool to "force" playback at 20FPS via an alteration of a file header or something similar that would not require re-encoding?
BTW -- the quality of the file with DVD2SVCD and CCE using D2SRoba and 1 one pass variable setting is great. If at all possible, I would like to do this with these tools. However -- whatever it takes.
Thanks for any assistance !!![]()
I think you can do this with avisynth. In my opinion, you can do a trick by repeating a field in each frame (upper, bottom, upper, bottom...) You will have 3 fields instead of 2 and 30 fps instead of 20. It's my theory, but I think it can work. After that you will slowdown from 30 to 29,97 fps.
AngusMcGyver,
Thank you for your reply. I would like to give your recomendation a try -- but I'm afraid AVISynth is not something with which I am very familiar.
**One of the reasons I like DVD2SVCD is that it somehow makes me appear to know what I am doing.**
I poked around looking for an example filter to ADD frames, but have not come across any. Do you know of one or could you post up an example? I consider myself a smart person and given a start could probably work through it.
Thanks !!
Richard
60 FPS avi - question
By pike8 in forum Video ConversionReplies: 10Last Post: 3rd Jan 2011, 16:45 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
MP4 29.97 fps to AVI 25 Fps
By videopetur in forum Video ConversionReplies: 4Last Post: 20th Jan 2009, 06:37 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
30 fps flv to 25 fps avi or vcd
By cd090580 in forum Video ConversionReplies: 5Last Post: 12th Nov 2007, 08:35
