  1. I have converted an avi file to mpg2 with TMPGenc, and it is 7Gb in size. Then I used TMPGenc Author to create the DVD files for me. Then I tried to shrink the DVD files to fit on a standard DVD disk, using DVD Shrink,but it reports an error/problem with the first VOB file and stops.
    How do I overcome this problem?
    I have used this method before on large files without any problems.
    Bob Heselwood
  2. Hmmz I also had problems with >4 gb mpgs...
    Now I use IFOEDIT 2 convert MPV + MP2 + Sup ---> VOB
    But I believe it won't work with single muxed MPG..
    U can demux the MPG with DVDLAB into MPV and MPA I believe
    and the use IFOEDIT
    But surely there's an easier way ... just don't now that way ...
