  1. Hey there,
    I have been getting a message from DVDit that I cannot find a way around. I put together the options that Iwant on the disc and then when I try to "build" the DVD or DVD folder I get this message:
    "The project contains an empty menu and cannot be built"
    I cannot figure out a way to delete the empty menu becase everyt ime that you use a menu it creates an empty one.
    Has anyone ran into this before and if so, how doI fix it. I have read Sonics website as well as the instructions that come with it and a few "How tos" on this site but none of them mention this.
    PJ[/b]
    All menus must link back to another menu, and no menu can be link-less. That when I get that error.
  3. Thanks LordSmurf...I totally forgot about that. Fixed it right up, except for the wav files being an unsupported sampling rate Which Ithink they are lying about. I'll find a way.
    Cheers
    PJ
    Cheers
    PJ
    Check the audio in SoundForge.
  5. Thanx I'll take a look.
    Cheers
    PJ
  6. Member Sugar's Avatar
    May 2002
    NY, USA
    You can use SSRC to resample.
