I am hoping to find a technical answer to this problem.
I have an IOMEGA +- Burner with the latest firmware and are using Shintaro 4x media which have a media code of Princo. I figured that to try and ensure a successfull burn, I would set NERO6 to burn only at 2x speed. Everytime I do this I receive verift errors at different areas of the disks.
I then started burning at 4x and 10 disks later, I have not had a problem.
Can anyone shed some light on why this would happen? Mayby something is done differently at 2x than 4x.
I dont have the exact media info and write strategy with me but if you would like to see it, i can get it.
Thanks in advance.
I didn't have problems with princo till a couple months after burning at 4x. Then they quite playing in my dvd players. Luckily I could still rip and burn to new media saving me another capture and backup. Avoid princo. Used A05 as a burner.Not sure why 2x is an issue however longevity is problem no matter what.
Burner can only burn to Verbatim Media, but not anymore...
By iownju in forum MediaReplies: 6Last Post: 19th May 2010, 06:53 -
Media does not burn at advertised speeds.
By nick101181 in forum MediaReplies: 14Last Post: 27th Feb 2010, 17:44 -
Can you burn at higher than the media advertised speed?
By tamgelikah in forum MediaReplies: 13Last Post: 19th Sep 2008, 05:57 -
What drive(s) CAN reliably burn cheap 8x DL media?
By miamicanes in forum DVD & Blu-ray WritersReplies: 20Last Post: 16th Feb 2008, 20:09 -
Media Will Not Burn - Even Though Firmware Is up To Date
By Lennoxtown in forum MediaReplies: 3Last Post: 30th Oct 2007, 14:38
