I have a movie that takes 700.1 Mb and I want to cut it back to 700 Mb so it will fit in a CD. Is there a way to do that with ffmpegX or w/ another app without having to re-encode it all? same question if I want to split a 1,4 Gb file in two 700 Mb files?
thanks
There is a "split" tool in the Filters tab, however it cuts at a given "start from" time, not at a given file size.
I've tried using the Split tool under filters and it shows a completed message but no new files are created. I'm using 0.0.9a.
Originally Posted by major
thanks for your reply ill try that -
it also wouldn't suprise me if you can fit a 700.1 mb file on a 700 mb cd.
Anyone agree? -
Originally Posted by sdm
Edit a movie (avi), cut some scene but KEEP subtitle in synq! HOW TO??
By GiBsom in forum EditingReplies: 5Last Post: 18th Dec 2013, 18:58 -
Cut DVD movie, is update necessary?
By dexter30 in forum Authoring (DVD)Replies: 2Last Post: 2nd Sep 2011, 06:55 -
Need Help with Movie Cut Short
By shalini72 in forum Newbie / General discussionsReplies: 7Last Post: 2nd May 2010, 01:02 -
Final Cut Pro Movie to x264 mp4
By skywriter in forum ffmpegX general discussionReplies: 0Last Post: 8th Feb 2010, 14:19 -
How to Cut out a scene in a movie using convertxtodvd
By tealmarlin in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2009, 07:49
