Greetings.
I own a Bluesky DV-1100 DVD player (no zone lock) bought in 2003 (Carrefour).
I would like to get more info about this unit:
1- Is it a clone of other DVD player brand?
2- Where should I check out for firmware upgrades?
3- Is there any code to disable Macrovision?
I have too little info about this model so any help would be apreciated.
Thank you.
I would also like to get the same info for Bluesky DV-710 DVD player.
Thank you. -
Experimenta aqui, companheiro.
[/url]http://www.regionfreedvd.net/players.html -
Obrigado.
Tenho os códigos (zone unlock) para os modelos referidos, se necessitares. -
Do you have the codes (zone unlock) for the Bluesky DV1100, because I can not get them.
Greetings.
1. Turn on the player with no DVD inside ;
2. On the remote control, press "Menu" ;
3. On the remote control, press "1 6 7 1 9" ;
Now you have access to a hidden menu.
4. Select "Configuration" and press OK ;
5. Change to zone number "0" (zero) ;
6. Exit and it is done, successfully unlocked.
This will work with Bluesky DV-1100 and DV-710.
Merry Xmas!
Best laptop for $1100 (Mastercam)
By neworldman in forum ComputerReplies: 2Last Post: 12th Mar 2011, 12:19 -
Quadro DVD HT 1100 new firmware
By betmeb in forum DVD & Blu-ray PlayersReplies: 0Last Post: 4th Aug 2009, 18:15 -
Why is an 1100 bitrate giving me a 6.5gb file when before it gave me 1.1gb?
By happyprozak in forum Blu-ray RippingReplies: 1Last Post: 27th Nov 2008, 14:10 -
Hack needed for Bluesky DV865
By litsa in forum DVD & Blu-ray PlayersReplies: 2Last Post: 27th Jun 2007, 00:20
